Mwatson's avatar
Mwatson
MR60 Xfinity Gateway Died…new modem, but no internet cabke recognition on MR60
My xfinity gateway died. Got a new gateway, hooked it up, but the MR60 reported no ethernet cable was plugged in. Tried dufferent cables, no change. Tested gateway ethernet ports, they are working. Bought a new cable modem, same problem, ugh, must be the MR60.
Have done factory reset on MR60. What other diags can i try?
  • plemans's avatar
    What actual modem/gateway did you buy or are you trying?
    • Mwatson's avatar
      Mwatson
      I have tried 2:
      I got another gateway from XFinity, same model as the last one, (running it in bridge mode), but the MR60 doesn't see the ethernet cable in the Internet slot.
      I also bought a NetGear CM2050V, because I wanted to get rid of the rental fee for the Xfinity gateway.  Same issue, MR60 doesn;t see the cable plugged in.
      I have swapped cables.  I have done a reset.  Not sure what else to try.
      • plemans's avatar
        Is the Mr60 still in warranty?
        Click on "mynetgear" at the top. register an account and the device.
        You should be able to check warranty status there
