Roxan
Aug 12, 2021Follower
MR60
Nighthawk mesh can not connect to router
michaelkenward
Aug 13, 2021Guru - Experienced User
You need help of some sort? If so, you'll have to say a lot more about your system and the problem you want to fix.
The MR60 is a Mesh router.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
I will ask the Netgear moderator to move your message.
