jgg1950
Mar 01, 2022Apprentice
MR60
Hello, I have MR60 with MS60 satellights Firmware v1.1.6.122. Both MR and MS show no devices connected on the network map? I had a case open (MS60 icon displayed as routers not mesh icons) while unde...
Mar 01, 2022Guru - Experienced User
what version of the app?
did you try clearing cache/data on the app?
jgg1950
2.14.0.1930 ,yes
- jgg1950Mar 01, 2022ApprenticeThanks for your time
- plemansMar 02, 2022Guru - Experienced User
Just checked mine. I'm on the same app version but android 10.
You tried uninstalling/reinstalling?
could just be an app update issue.
You might have to use the browser and wait until the next app update.
- plemansMar 02, 2022Guru - Experienced UserOr you can try a scorched earth tactic and factory reset the router and uninstall/reinstall the app and then the router.
