Pindiak
Apr 18, 2022Tutor
mr60,
trying to replace old nighthawk router that has several internet plugs to nighthawk mesh wifi & router mr60 but it only has one internet plug. Need to plug in direct tv and computer. do i get a split...
Apr 26, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
