BLZ6353
Mar 20, 2023Guide
MR60
I have purchased a MK6W system with one MR60 and two MS60 satellites in June 2022 and set up in a large, 3 level, vacation home. Purchased a second system December 2022 and connected the two addition...
- May 18, 2023
I would move the farther MS closer. 60' could be a bit too far if the MS are dropping off here and there. Need to stabilize them.
Try using channels 1 and 40 or 11 and 48.
Mar 21, 2023Guru - Experienced User
Got teamviewer on any of the computers there?
You could remote into one of them and use the GUI at that location. Sometimes the gui displays things the app doesn't.
And you could potentially log into the satellites ip address and remote update them that way.
- BLZ6353Mar 21, 2023Guide
No, unfortunately don’t have any computers connected being a vacation house. Will bring a laptop with me and log into the routers and satellites next time I’m there to double-check the firmware.
