BLZ6353
Mar 20, 2023Guide
MR60
I have purchased a MK6W system with one MR60 and two MS60 satellites in June 2022 and set up in a large, 3 level, vacation home. Purchased a second system December 2022 and connected the two addition...
- May 18, 2023
I would move the farther MS closer. 60' could be a bit too far if the MS are dropping off here and there. Need to stabilize them.
Try using channels 1 and 40 or 11 and 48.
BLZ6353
May 17, 2023Guide
Now at 3 weeks from reducing satellites down to only 2. However, devices continue to disconnect over time. Now at 7 devices in total vs. only one after 3 days. In the Nighthawk app, some of the 7 are showing as still connected while some are not. I can reboot the router via Anywhere Access but am cautious as it may reboot with fewer security cameras connected and operating than before the reboot. Any other suggestions to resolve the slow dropping of devices? Next visit, I will probably install WiFi power switches on the 2 satellites that had remained powered up and connected so I perhaps could reboot individual satellites in addition to the MR60 router.
May 18, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)?
What channels are you using?
Any Wifi Neighbors near by? If so, how many? And what channels are they using?
- BLZ6353May 18, 2023Guide
Distance between router and satellites is 40 - 60’. Will have to check on the channels being utilized
during next visit; should have been whatever default channels are from a typical set-up (auto?). Neighbors are at least 100 yards away. Will have to perform a scan as to what channels they are using but neighbors were showing up as weak WiFi signal(s).
- FURRYe38May 18, 2023Guru - Experienced User
3 level house. Router is placed on mid-level side where cable enters house. The 2 satellites are placed on the top level, different rooms, spaced 30 - 40’ apart. The closest satellite to router is 30 - 40’. Some of the devices disconnected are perhaps in the range where they are close to equidistant from the 2 satellites. However, a couple of devices disconnected are in the same mid-level room as the router and these disconnected earlier than the others on the top level.
- BLZ6353May 23, 2023Guide
Finally got back to the house and router. The channels were at auto and 163. Changed to channels 6 and 48 and this appears to have immediately resolved the devices disconnecting problems. After 3 days away from location, everything is still connected and working.
- FURRYe38May 24, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
