BLZ6353
Mar 20, 2023Guide
MR60
I have purchased a MK6W system with one MR60 and two MS60 satellites in June 2022 and set up in a large, 3 level, vacation home. Purchased a second system December 2022 and connected the two addition...
- May 18, 2023
I would move the farther MS closer. 60' could be a bit too far if the MS are dropping off here and there. Need to stabilize them.
Try using channels 1 and 40 or 11 and 48.
BLZ6353
May 18, 2023Guide
Distance between router and satellites is 40 - 60’. Will have to check on the channels being utilized
during next visit; should have been whatever default channels are from a typical set-up (auto?). Neighbors are at least 100 yards away. Will have to perform a scan as to what channels they are using but neighbors were showing up as weak WiFi signal(s).
May 18, 2023Guru - Experienced User
- BLZ6353May 18, 2023Guide
3 level house. Router is placed on mid-level side where cable enters house. The 2 satellites are placed on the top level, different rooms, spaced 30 - 40’ apart. The closest satellite to router is 30 - 40’. Some of the devices disconnected are perhaps in the range where they are close to equidistant from the 2 satellites. However, a couple of devices disconnected are in the same mid-level room as the router and these disconnected earlier than the others on the top level.
- BLZ6353May 23, 2023Guide
Finally got back to the house and router. The channels were at auto and 163. Changed to channels 6 and 48 and this appears to have immediately resolved the devices disconnecting problems. After 3 days away from location, everything is still connected and working.
- FURRYe38May 24, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
