AH_1876
Jul 08, 2024Follower
MR60
Bij het opstarten/updaten van de MR60 werd de internetverbinding onderbroken. Nu blijft de LED wit knipperen. De voeding verwijderen en opnieuw aansluiten bracht geen oplossing. De resetknop achteraa...
Jul 11, 2024Guru - Experienced User
Any progress on this?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
AH_1876 wrote:
TRANSLATION : The internet connection was interrupted when starting/updating the MR60. Now the LED continues to flash white. Removing the power supply and reconnecting it did not solve the problem. Pressing the reset button at the back for 7 seconds and restarting did not solve the problem. I cannot connect to the router to manually restore the firmware. Who can help me
