earsdr
Dec 24, 2020Initiate
MR60/MS60 -- Router will not see and sync with satellites
After mos of flawless function, my Nighthawk MR60 router has dropped the satellite and will not see it to re-sync. Using iPhone Netgear Nighthawk app to add satellite causes both MS60 satellite and ...
- Sep 23, 2021
I had the same issue. I updated the firmware on my sattelites (Nighthawk MS60) and the LED on one sattelite would continue to blink white like it was trying to connect to the MR60 main router. The blinking never stopped and I couldn't see the sattelite connection anywyhere. I found instructions on how to update the firmware for NETGEAR routers using TFTP. I downloaded the latest firmware from the MS60 support page and then I followed these instructions exactly:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
This will allow you to reinstall firmware to your router directly, not using the app or routerlogin.net, since they were unable to see the sattelite in the first place.
I installed the latest firmware on to the sattelite again and it worked again instantly. Once it was done rebooting, it searched for the MR60 and flashed white, turned amber for a couple of minutes, then finally settled on solid blue. Success!
I hope this helps anyone else with this issue. It seems like this isn't uncommon for the firmware update to soft brick these sattelites. Netgear wasn't exactly helpful either with their $50 or more support paywall.
rjhaack
Jan 04, 2021Tutor
I am having the same issue. It seems like maybe after these updated to the latest firmware is when my issues started. I can get them to sync if I use a network cable to connect them but once I remove the cable it stops working. I have even reconfigured the MR60 thinking something happened but that did not solve the issue. My MS60 and MR60 are on the same firmware V.1.0.6.102.
Is there someway to revert back to the previous firmware version to see if they work again?
Mlewis80
Mar 07, 2021Aspirant
Have you all figured out a fix to this problem? One of my satellites dropped the other day and now both have dropped connection.
