cs47
Jan 21, 2022Tutor
MR60/MS60 - Ethernet backhaul creates network loop
I have an MR60 router connected to the internet and 2 MS60 satelites connected with an ethernet (cat-6) backhaul. I bought this device at Costco - strange that the model number is not listed in the ...
Jan 21, 2022Guru - Experienced User
How are the MS connected to the MR? Directly to the back of the MR or is there a LAN switch in between the MR and the MS?
If there is a LAN switch, brand and model# please.
What CAT# cables are you using? CAT6 is recommended.
Check cables between the MR and MS.
Is both MS doing this or only one?
Swap MS locations with each other to see if problem follows.
TheBoroer
Jan 24, 2022Aspirant
I just want to chime in and say i'm experiencing the same issues.
I just upgraded to 1.1.6.122 yesterday on all devices to see if that fixed the issue but it doesn't.
I have one MR60 and two MS60 devices connected via cat6 ethernet cables to a Mikrotik RB5009 router (I also tried having them connected via an unmanaged switch with the same result). The netgear mesh system is configured to be running in Access Point mode (AP Mode).
All 3 netgear devices are connected directly to the mikrotik router and I see loop detection warnings in the mikrotik logs.
- FURRYe38Jan 24, 2022Guru - Experienced User
If your ethernet connecting the MS, they need to be connected to the back of the MR, not in parallel at the host router.
ISP Modem>Host router><>MR in AP mode<Unmanaged LAN switch<>MS connected to Lan Switch.
- redcdaleJan 31, 2022Tutor
I'm seeing the exact same thing. I've been using firmware 1.1.6.122_2.0.58 since sometime in December, and I've run into the loop issue twice. The first time, I used wireshark to trace down the offending device, and after turning it off, I still saw the packet storm. Only when I disconnected one of the ethernet backhaul cables connected to one of my MS60s did it stop.
I'm suspecting that the satellite(s) are somehow enabling both the ethernet and the wifi backhaul and this is causing a loop. Is there any way to confirm/deny this? I wish Netgear would give us some more control make sure the wifi backhaul is disabled.
- FURRYe38Feb 01, 2022Guru - Experienced User
How is the MS connected to the MR? Directly behind the MR or is there a LAN switch in between or is the MS connected to a different router with the MR in parallel?
- redcdaleFeb 01, 2022Tutor
The MR60 is my router, connected directly to my FIOS on the WAN side, and on the LAN side, there are 2 unmanaged switches between the MR60 and each MS60. One satellite is connected via a Netgear GS208 and a Tenda G1005D and the other one is connected via the same Netgear GS208 and a TP-Link TL-SG105.
