cs47
Jan 21, 2022Tutor
MR60/MS60 - Ethernet backhaul creates network loop
I have an MR60 router connected to the internet and 2 MS60 satelites connected with an ethernet (cat-6) backhaul. I bought this device at Costco - strange that the model number is not listed in the ...
Jan 21, 2022Guru - Experienced User
How are the MS connected to the MR? Directly to the back of the MR or is there a LAN switch in between the MR and the MS?
If there is a LAN switch, brand and model# please.
What CAT# cables are you using? CAT6 is recommended.
Check cables between the MR and MS.
Is both MS doing this or only one?
Swap MS locations with each other to see if problem follows.
cs47
Feb 01, 2022Tutor
Hardware Version MR60 Firmware Version V1.0.6.116_2.0.54
This device is connected directly to the Verizion FIOS termination equipment - I returned the Version modem and router.
Everything is CAT-6 cabling although one of them is long - 30FT to get from the garage where the MR60 is located to the satelites in the main house.
There are 2 GS 108T switches in the network.
FIOS <-> MR60 <-> GS108T <-- long cable --> GS108T <-> MS60
At one point I remove the far switch and just connected the MS60 directly to the first switch but that didn't seem to make a difference.
- FURRYe38Feb 01, 2022Guru - Experienced User
What happens if you remove both switches and set the MS directly connected to the MR?
cs47 wrote:
Hardware Version MR60 Firmware Version V1.0.6.116_2.0.54This device is connected directly to the Verizion FIOS termination equipment - I returned the Version modem and router.
- cs47Feb 01, 2022Tutor
It sometimes takes a few days or a week for the situation to occur. I can't have my home network offline for that long.
Some of my devices are hard-wired only and without a switch I can not use them.
Also, as there is only one port on each device, it isn't possbile to configure them all without at least 1 switch.
Possible that your switches could be a cause as why to the suggestion.
What Rev version is your GS-108Ts? I see 3 different versions.
