Nick57
Nov 25, 2020Aspirant
MR60/MS60 extremely slow WiFi speeds
Nighthawk WiFi 6 Mesh system is produces maxiumum speeds of 30mbs on a gigabit line. Even 30mbps only occurs in direct line of sight from the main router with a max speed of 15mbs off of one satelite...
Nick57
Edit: Direct router Speedtest shows 600mbs and wired connection directly to main router shows similar speeds. Issue is only with wireless
- Christian_RDec 02, 2020NETGEAR Employee Retired
Hi Nick57,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
