s88urd's avatar
s88urd
MR60/MS60 Firmware
Hi, recently purchased this system and to be honest it has been a bit of a nightmare to get it setup to my liking. Weirdly I had to create a new netgear account and unregister from the original and r...
  • s88urd's avatar
    s88urd
    May 14, 2024
    Appreciate your reply, thankyou.
    I had issues as I originally set up a guest network and had all my IOT devices connect to that. This then caused issues with an Alexa stereo pair (with subwoofer) so I disabled the guest network and used a customized 2.4GHZ one. Unfortunately I dont know what happened but after doing that most of my devices (IOT and 'normal') wouldnt connect. The only way around it was to reset to defaults and setup in this way from scratch (i.e. not enable the guest network)
    This then lead to further issues with the app (understand its not the routers fault) as devices were being disaplyed on the webgui but not showing on the app unless I activated SPC (which always failed)
    Ive managed to get it working (touchwood) by setting it up as intended the first time. I also had to de-register the products from my existing netgear account and create a new one to register them too (again not a firmware issue)
