crazyoldhermit
Apr 16, 2023Star
MR60/MS60 slow wifi and wired backhaul issue
Topology - Motorola SurfBoard (Spectrum ISP) > Netgate SG-2100 > Netgear GS108Tv3 > several unmanaged switches and my devices, including the MR60 in AP mode, and the MS60 as a satellite. Firmwar...
crazyoldhermit
Apr 16, 2023Star
Ok Michael, let's dive into your response a little -
1. I am not expecting the AP to provide faster speed than a wired connection. The capabilities of the device and the Wifi6 spec are pretty clear that I should be getting better speeds than what I currently do.
2. In my shoes, rat's nest? What exactly is a rat's nest about my setup? I have wifi provided by the Nighthawk Mesh, my router is rock solid modern pfSense appliance. Like many people, I have little stars happening at my media center, my office, and the NAS, with simple switches feeding the devices. Everything is wired except for mobile devices. So, if having a Netgear managed switch in front of Netgear devices that are advertised as being AP capable, then absolutely shame on me for this rat's nest.
Really, your post is the opposite of helpful and does not make you look at all like an expert. Thanks for the response, and if you care to clarify what exactly is a rat's nest here that would be great.
Apr 16, 2023Guru - Experienced User
I'd start back simple.
Connect the MR60 directly to the primary router.
Make sure the MR60's internet connection is into the wan port. then connect the switches afterwards and the satellites to the MR60's lan port.
so go:
primary router----> wan port MR60--->lan port mr60---->switches/satellites.
