jgg1950
Nov 21, 2021Apprentice
MR60/MS60 the satiilites icon display as routers?
Hello, My MS60's display as router icons not mesh satillites , Firmware V1.0.6.116. at 1st install they were the right icon? The model field doesn't have MR60 or MS60 as an option. Thanks
jgg1950
Screen shot doesn't attach? I tried attach photos and attach file?
Nov 21, 2021Guru - Experienced User
I wouldn't worry about what icon they're showing up with, they're identifying as a satellite which is the proper response.
More than likely just an app but on displaying.
- plemansNov 21, 2021Guru - Experienced User
Since I don't have one to compare with, I can't say if its isolated to your app, that version of the app, OS, or what exactly.
Maybe ChristineT can forward it to someone who does know :)
- jgg1950Nov 21, 2021ApprenticeOk, but at 1st they displayed as MS60 icons, then changed to router icons. Nothing changed on Android or the devices.
could have been an app update
Was this forwarded to Christine?
Thanks
- plemansNov 22, 2021Guru - Experienced User
She's tagged in it. That's about all we can do
