jgg1950
Nov 21, 2021Apprentice
MR60/MS60 the satiilites icon display as routers?
Hello, My MS60's display as router icons not mesh satillites , Firmware V1.0.6.116. at 1st install they were the right icon? The model field doesn't have MR60 or MS60 as an option. Thanks
Nov 21, 2021Guru - Experienced User
I wouldn't worry about what icon they're showing up with, they're identifying as a satellite which is the proper response.
More than likely just an app but on displaying.
Since I don't have one to compare with, I can't say if its isolated to your app, that version of the app, OS, or what exactly.
Maybe ChristineT can forward it to someone who does know :)
- jgg1950Nov 21, 2021ApprenticeOk, but at 1st they displayed as MS60 icons, then changed to router icons. Nothing changed on Android or the devices.
- plemansNov 21, 2021Guru - Experienced User
could have been an app update
Was this forwarded to Christine?
Thanks
- plemansNov 22, 2021Guru - Experienced User
She's tagged in it. That's about all we can do
- jgg1950Nov 22, 2021Apprentice
Thanks
- ChristineTNov 29, 2021NETGEAR Employee Retired
Hello jgg1950 ,
Let me get this booted up the chain and see if we have made any recent changes that would have contributed to this issue.
I'll be back in touch as soon as I have an answer. I'm going to loop in DarrenM who can also help me track this down.
plemans - Thanks for the shout-out!! ;-)
Cheers,
Christine T
- jgg1950Nov 29, 2021Apprentice
Thanks Christine
