jgg1950
Nov 21, 2021Apprentice
MR60/MS60 the satiilites icon display as routers?
Hello, My MS60's display as router icons not mesh satillites , Firmware V1.0.6.116. at 1st install they were the right icon? The model field doesn't have MR60 or MS60 as an option. Thanks
jgg1950
Feb 13, 2022Apprentice
This ticket was closed ? it was reported prior to the 90 day expiration with no
resolution ? I supplied all documentation as requested, I guess thats their way to not fix the problem? Any suggestions?
| 45449359 | MR60 | Closed | MR60_NH app issue: on the network map, satellites are showing icons for the router not for the satellites |
Feb 14, 2022Guru - Experienced User
Since november when you were talking with them, there has been app and firmware updates.
Did those help?
- jgg1950Feb 14, 2022ApprenticeHello, No if you look at the ticket you'll see all that occurred and the latest firmware version. They said they were working on a fix which they haven't gave me.
Thanks - plemansFeb 14, 2022Guru - Experienced User
jgg1950 wrote:
Hello, No if you look at the ticket you'll see all that occurred and the latest firmware version. ----this is the public support forum. Its members of the public helping out. We're not netgear and don't have access to the tickets/issues. The mod's do but they're a bit more rare on here. Any updates ChristineT DarrenM - jgg1950Feb 14, 2022ApprenticeHello, If your asking about updates there are none other than they closed the ticket?
Was more asking the mod's if they had any updates. That's why I linked to them.
- jgg1950Feb 14, 2022ApprenticeThanks
