BLZ6353
Jul 04, 2023Guide
MR60/MS60 WiFi devices not reconnecting after power failure
I have a MK6W system, one MR60 and two MS60 satellites since June 2022 set up in a 5,000 sq. Ft., 3 level vacation home. The satellites are spaced 30 - 40 ft away from the router. Router and satelli...
BLZ6353
Jul 05, 2023Guide
I had problems with devices dropping over time on this router/system until I changed the channels and then it was solid until this lengthy power failure. The satellites show that they’ve connected to the router in the Nighthawk app. Used to utilize an AC1200 at this residence until I upgraded last year and did not have these numerous connectivity issues whether after power failures or over time. Hoping to resolve these issues with the Mesh system and not have to revert to the old router or probably a new non-mesh system. Difficulty being a vacation so often not there to check things out in person when attempting troubleshooting.
Jul 06, 2023Guru - Experienced User
30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected. Try the MS a bit closer to the MR?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Does this happen if you turn OFF one of the MS?
Try setting manual channel 1 on 2.4Ghz and 40 on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- BLZ6353Jul 17, 2023Guide
It being a vacation house, just got a chance to visit and respond. I have a Linksys CM3016 cable Enclosed is the surrounding WiFi. Changed my channels to 3 and 40 Did the restart of everything from scratch and set the DHCP IP as stated. Surprisingly, when I was setting up again, it’s only the router operating and no satellites yet connected, my devices were all connected albeit the distance ones weak, -80dBm+. With the satellites properly spaced and positioned, strong signals to everything. So, no just have to wait for the next lengthy power failure and hope everything reboots and reconnects
- FURRYe38Jul 18, 2023Guru - Experienced User
Kinda busy around there.
Primary channels to use are 1, 6 or 11. Others are 2ndary used by the wifi system. You might try channel 6.
- BLZ6353Jul 18, 2023Guide
I had it set on channel 6 previously, when had the devices not connecting after power failure. Will revert back to 6 next time I’m at the location. More neighboring signals than I expected; perhaps carrying up the slope from the lake below.
