K9DAK
Jan 28, 2021Aspirant
MR62 Mesh and HP WiFi Printer
Hi all... I have an HP ENVY 5660 WiFi printer that refuses to work with my new MR62 mesh system. Everything else on the network works perfectly. If I unplug the satellite (located about eight feet ...
Jan 28, 2021Guru - Experienced User
Are you leaving the printer off the network and just connecting to it when you want to print?
If you connect it to the network, you can set it up as a network printer.
- K9DAKJan 28, 2021Aspirant
No, it's powered on and connected to the network 24/7 as a network printer.
Cheers,
Dave
