OldGeezer1938
Sep 22, 2021Follower
MR63 - Armor Protection.
How to I stop Armor Protection? It is blocking almost everything I attempt to login to. Including my Netgear account when using my Password Manager. Joe Werner jwwerner.9963@gmail.com
Sep 22, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Best way for you would be to factory reset the MR and setup from scratch and this time, don't enabled Armor.
Good Luck.
