PMFlyer
Mar 18, 2021Tutor
MR63 nighthawk mesh router Internet Speed throughput
What kind of throughput can I expect from my main router M63 Nighthawk Mesh WiFI router, I have 350/350 input with ethernet 150/25 and WiFi 300/40? Not sure if it should take it back and get another ...
Mar 18, 2021Guru - Experienced User
I don't have a MK system so can't attest to its speeds/performance personally. I haven't seen a whole lot of testing on it but one tester (https://dongknows.com/netgear-nighthawk-mk63-review/) hit much faster speeds than what you're seeing.
What modem do you have?
What firmware is on the router?
How are you speedtesting? (device, site, etc)
- PMFlyerMar 18, 2021Tutor
Thanks the article was helpful. The modem is an ATT BGW210-700, I have the latest firmware v1.0.6.110,
Speedtesting - Computer to modem using Ookla speed test 350/350, Nighthawk app 350/350 Computer to ethernet on the router 150/25 computer to WiFi 300/40
- plemansMar 18, 2021Guru - Experienced User
that att device has its own integrated router. it can cause a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
options? (only use 1)
1. put the att device in passthrough/modem only mode. Att hasn't made it easy with this route.
https://www.reddit.com/r/Ubiquiti/comments/b1x5l6/how_to_properly_configure_the_arris_bgw210_for/
2. Put the netgears IP address into the att's dmz.
3. put the netgear into access point mode. this leaves the att device controlling routing. wifi/ethernet all still work, you just loose some features. https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
Thanks I will give it a try and let you know. I have to do it on off work hours and when the family is not online
