MinGin
Aug 07, 2024Tutor
MR70 and MS70 Download Speed Problem
I am bought MR70 and MS70 in recent day. It found that the download speed is extremely slow via this mesh router..The download speed is around 80Mbps and upload speed is find (~900Mbps) via wired (PC...
Aug 07, 2024Guru - Experienced User
What speed testing app are you using on the PC and phone? Ooklas installable is recommended.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- MinGinAug 07, 2024Tutor
Ans: Yes, I am using Ooklas
Ans: Those function are disabled
Ans: EchoLife HG8040H5 (I am not live in US)
Ans: Yes, CAT6 is using for all connection (Modem to Router, Router to PC etc)
When i change back to Netgear LAX20, then everything return to normal (Download: ~900Mbps / Upload: ~900Mbps)
Maybe i click something wrong in the website. The problem is not solved yet.
Because the website show different wording (nor English) in English web page
- FURRYe38Aug 07, 2024Guru - Experienced User
Try something, if you can, disable the WiFi radios on the LAX20.
Connect up one ethernet cable to the MR70 while it's not connected to anything and change it's IP address from 192.168.1.1 to 192.168.0.1 and apply the change.
As the MR reboots, connect it's WAN port to a free open LAN port behind the LAX20.
MR should get a front LED thats BLUE.
If and when it does, run another speed test with the one PC connected behind the MR while it's connected to the LAX20...
LAX20 and MR70 are not using at the same time
So, LAX20 is power OFF when MR70 is turning ON.
It is just a comparison of download speed between MR70 and LAX20, which MR70 is extremely slow.
