BjornJ73
Aug 13, 2025Aspirant
MR70 does not lock out devices
I run a MR70 with two MS70 satellites and the connections is working well, so is access to the system via web-browser or app. But when I block a device that's on the network it displays as "blocked" ...
CrimpOn
Aug 13, 2025Guru - Experienced User
Well, fudge. This is WRONG.
- We know it is not possible to "Pause" the device that is running the 'app' (because that is logically inconsistent).
- Blocking a device does not prevent the device from connecting. It only prevents the device from sending traffic through the MR70 system.
(That is why it will show up as "Connected", but Blocked.) - For example, if two Ethernet devices are connected to an Ethernet switch that is also connected to the MR70, those two devices can communicate all they want over Ethernet because their communication never leaves the switch and enters the MR70. They will show as Blocked.... but not to each other!
I have had episodes on the web interface where I made a setting but neglected to click on "Apply" at the top of the screen. Left the screen and my 'changes' never happened. Do not know if the Nighthawk app has a similar feature.
BjornJ73
Aug 15, 2025Aspirant
Yes, devices are connected regardless of pause/block. But they should not be able to access the internet. I believe it’s worked as expected before but can’t say when that changed. Next step is resetting the system as close to factory reset as possible, then set it up again from scratch. That doesn’t work I’m going to have to buy a complete new system, Netgear won’t be high on the list of candidates if it comes to that :-(
