craigc8
Jan 16, 2024Aspirant
MR70 Mesh Wifi 6 Router Conneted With No Internet
Hello, I am using the MR70 Mesh router with two MS70 satellites. Some, not all, connected devices will periodically lose internet connection, while other devices are unaffected. For example, I will b...
craigc8
Thank you for the quick reply.
Firmware version V1.0.3.34_2.0.58
Hitron Tech EN2251 Modem
Home is three levels, about 4400 sq ft of coverage area. The MR70 router is in the corner office on the top floor. There are two MS70 satellites, one in the center of the middle floor and one centered on the bottom floor. The router is over 30 feet from the satellites, but there is not more than 30 feet between the satellites. Perhaps only one satellite is needed?
I will try changing the MAC settings on our phones/tablets to see if that keeps them connected to the internet. Should the MAC setting ever be changed back to random when the device is outside of our home network?
Jan 16, 2024Guru - Experienced User
Try turning OFF one RBS and see if the behavior changes.
Yes.
