lgrekstas
Jul 12, 2024Follower
MR70-MS70 one satellite unit will no longer connect
Mesh has one base unit (MR70) and 2 satellite units (MS70). One satellite unit connects successfully but second unit will not connect. System was working fine, until suddenly second unit no longer ...
Jul 12, 2024Guru - Experienced User
Does the one MS connect wirelessly with the other MS turned OFF?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡 🛰️
What channel configurations are currently set on the router?
