Nick22
Feb 22, 2024Aspirant
MR70-MS70
 I'm working for a call center & we have 2 MR70 with 2 MS70 & about 60 computers. Our internet comes into & connects to 1 of the MR70 & have a line running to the other MR70. We are running a very fas...
Nick22
Mar 12, 2024Aspirant
Is MU-MIMO really worth turning on. I'm getting mixed feelings about turning on the option from what I read. OFDMA is on & BEAMFORMING is also on. With the amount of computers on the system (just about 30 each). Just looking for suggestions. Thanks
Mar 12, 2024Guru - Experienced User
I'd base your feelings on weather it works or not for you. Try it out and if it's doesn't work or make it better you can disable it. MIMO is mainly for devices that have MIMO support.
