helpplzz
Apr 07, 2023Guide
MR70: Red Light
My router has the red light, I have tried unplugging & hitting the reset button - to no avail, it stays red. Will not connect, but it is just over 3 months old! My internet guy said the router is 'fr...
- Apr 07, 2023
helpplzz wrote:
I tried calling the support number on the netgear website, but the dude tried to say my 'firewall' expired and tried to get me to pay them hundreds of dollars.
Is this a scam? I am about ready to report Netgear to BBB for fraud.
Yes.It is a scam. Nothing to do with Netgear.
The clue is in the "firewall" bit.
Let me guess.
You Googled "Netgear support". You clicked a link it found. You landed on a website with a phone number you called.
After the 90-day set up period for mew purchases Netgear doesn't run its own support system. It farms it out to Gearhead. But they won't try selling up a firewall, just a support contract.
Rather than waste your time with whatever BBB might be. Tell us who you called and the website you found. Then we can pass that on to Netgear who may unleash their own lawyers on the case.
My internet guy said the router is 'fried'.That is another scam that we see all the time.
When they really mean is "I don't have a clue as to what is going wrong. So let's pass the buck back to the customer".
So go through the process that FURRYe38 has unleashed.
helpplzz
Apr 07, 2023Guide
Tried all of that, keep getting error message.
Apr 07, 2023Guru - Experienced User
What error message are you seeing and where are you seeing this message?
Does a ethernet connected PC get an IP address from the MR?
Try a 30-30-30 reset process with the MR disconnected from the modem/ONT and 1 wired PC connected to the back of the MR.
Look up on line on how to do this.
- helpplzzApr 07, 2023Guide
yes, i can get an IP - but when i try to log in to the router settings, all i get are error messages.
why would modem affect it? ISP came out and said everything is working as it should, except the router. Has been fine for past 3 months with same everything.
- FURRYe38Apr 07, 2023Guru - Experienced User
So it's hard to be helpful to you if you don't answer or give feedback to the questions presented.
If your not willing to give feedback here so we can attempt to help you then you'll need to contact NG support:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/Good Luck.
yes, i attempted calling support from the number listed on their website - but they said i need to pay hundreds of dollars to activate a firewall subscription (which is why i had assumed fraud)
