LordyJordy
Sep 16, 2024Aspirant
MR70 Router Wont Stay Connected
Hello as the title states i am having issues keeping my mr70 connected to the modem. I had Spectrum come out numerous times until they finally said everything looked good on their end. Then i turned t...
Sep 16, 2024Guru - Experienced User
Does the front LED on the MR turn AMBER when this happens? If so, this means the MR is failing to get a good signal from the ISP Modem/ONT or the modem or ONT is not getting signal to the MR correclty. Possible bad cable in between. CAT6 UTP cabling is recommended.
- LordyJordySep 16, 2024AspirantIts cat 6 cable I only run cat 6 cables for everything. Believe yesterday when looking in ap it was firmware 1.03.4 or something like that. Netgear app kept saying it was currently up to date. As far as the numbers go for spectrums modem id have to answer back later as im at work. Roommate told me it was down again so i know its something with mesh system i just cant fogure out.
- FURRYe38Sep 16, 2024Guru - Experienced User
1.0.3.34?
Lets know about the other feedback...
- LordyJordySep 16, 2024AspirantSorry for delayed response but yes thats the firmware version. Mfr appears to be just Spectrum? Model number im not sure would it be the same as the serial number?
