ducslayer
Jan 19, 2024Tutor
MR70 satellite won't sync
One of the satellites dropped connection with MR70 router. LED shows amber. Tried syncing many times with satellite right next to router. power both off many times. firmware is current. connecte...
- Jan 22, 2024
I presume you mean WPA3?
If it's supported, would be under Basic tab/Wireless settings. Be careful though, There may not be a WPA2/WPA3 mixed mode setting so if you set it to WPA3 only, Some of your non WPA3 devices won't work if this option is set. You'll need to leave it WPA2.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jan 19, 2024Guru - Experienced User
What Firmware version is currently loaded and the MR and any other MS?
Turn off the other MS if present.
Power OFF the MR and this MS.
Power ON the MR and let it come to ready. With this one MS in same room, not close to the MR, after it shows a solid LED, AMBER or blinking LED, use the MRs web page to add the MS to the MR. See if this gets it re-synced.
ducslayer
Jan 19, 2024Tutor
Hi Fury, Thanks for the quick response. Firmware is V1.0.3.34. I will try your recommendations and get back to you in bout 1 hr. Thanks again!
