ducslayer
Jan 19, 2024Tutor
MR70 satellite won't sync
One of the satellites dropped connection with MR70 router. LED shows amber. Tried syncing many times with satellite right next to router. power both off many times. firmware is current. connecte...
- Jan 22, 2024
I presume you mean WPA3?
If it's supported, would be under Basic tab/Wireless settings. Be careful though, There may not be a WPA2/WPA3 mixed mode setting so if you set it to WPA3 only, Some of your non WPA3 devices won't work if this option is set. You'll need to leave it WPA2.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
ducslayer
Jan 19, 2024Tutor
Your awesome!!!!! all back up and running all MS's. One other quick question, I remember setting it to WAP 3 for high security. can't find that setting? Thanks again Furry
Jan 22, 2024Guru - Experienced User
Enjoy. 📡
- ducslayerJan 25, 2024Tutor
Hi Furry,
sorry for the delay. yes, WPA. sorry for the typo. I will take your advice and leave it be. the outers and satellites are working perfectly now and have been since the factory reset. Thank you again so much for your expert help!
- FURRYe38Jan 26, 2024Guru - Experienced User
