JFMUSIC
Aug 09, 2022Aspirant
Mr70 Will not give better then 90 Mbps on Hardwire...
I have had an open ticket for weeks with tech support. And had no response to my last six emails. Has anybody else seen this issue and has there been any fix? Or Am I returning yet again another...
Aug 09, 2022Guru - Experienced User
What CAT# lan cable are you using? CAT6 is recommended.
What is the brand and model# of the ethernet adapter in your PC that your using?
Be sure this ethernet adapter is connecting at 1000Mbps to the MR.
JFMUSIC
Hi Thanks
| Firmware Version | V1.0.2.26_2.0.53 |
For the Record... Wireless is pumping 400+ on a 460 mbps Spectrum.
So, that means the WAN to the Router and the WIFI Circuit are pumping what one would hope.
Cat 6 Cable
Apple MacBook pro 2017
I have tried three other routers and all three as expected, pump 400+ on the Hardwired.
Unfortunately they also, failed on WIFI and only pumped 90 ish Mbps on the WIFI.
So, not the connectivity from the Modem to the Router and not the ISP.
IT IS THE ROUTER.
Unless i am really missing something.
- FURRYe38Aug 09, 2022Guru - Experienced User
What is the connection rate seen on the MBPs Hardware tab seen on the ethernet connections networking page in the Networking settings when it's connected to the MR?
Be sure to not enable Access Controls, Armor, Circle, QoS or Traffic Meter after you reset and setup from scratch.
- JFMUSICAug 09, 2022Aspirant
I realize the need to understand the setup to offer best guess.
1000mbps on the LAN ports.
The modem is not the cause if the WIFI can Consistently pump 400+
If it was the modem then Both the WIFI and the Ethernet would be slow.
Unless there is something really odd about how the MR70 pumps data that I am missing.
A bottle neck at the entry point would mean loss at both exits, not just one.
None of your list to leave off, are on.
This is the NEW replacement of the last which I returned after a week and the recommendation of tech support to return and try another.
They thought it was a bad Ethernet port.
I suppose it could be a cluster of bad systems with bad Ethernet ports.
