JFMUSIC
Aug 09, 2022Aspirant
Mr70 Will not give better then 90 Mbps on Hardwire...
I have had an open ticket for weeks with tech support. And had no response to my last six emails. Has anybody else seen this issue and has there been any fix? Or Am I returning yet again another...
JFMUSIC
Thank you for your kind explanation.
I will take it to heart.
BUT,
As you state in your description, if it where the Modem connection...
if it is stable ish, for the WIFI.
It can't be the modem connectioin to the router, or the wifi would suffer the same problem as the Hardwired.
Aug 09, 2022Guru - Experienced User
Anything is possible. Something to try with a different modem to see if the ethernet problem follows. Otherwise, let NG support know about this.
