Guntervl
Sep 23, 2026Guide
MR70/MS70, no wired backhaul?
I am trying to get wired backhaul to work. Wirelesly the satellites are found. They connect and show up in the admin ui as connected wirelesly. When I plug in a network cable to the satellite the led...
Guntervl
Sep 23, 2026Guide
At first, I didn't try directly but I now did and it worked. My config is like this picture only with added pfSense router on the same switch, Nighthawk in AP mode and cable in the WAN port as per the manual:
To set up the router as an AP:
1. UseanEthernet cable to connect the Internet port of this router to an Ethernet port
on the other router
