gwlester
Sep 04, 2023Tutor
MR80: "192.168.1.1 refused to connect." -- from both Nighthawk Andriod App and laptop prowser
- Sep 05, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
gwlester
Sep 05, 2023Tutor
A full power reset (unplug and wait 60 seconds) solved the issue.
Thanks to everyone who responded.
Sep 05, 2023Guru - Experienced User
Enjoy. 📡
