sjkoretz
Oct 29, 2022Aspirant
MR80 and 4 satellites
I setup a MR80 latest firmware with 2 satellites. Using Windows and IOS. I needed to add another satellite which I just purchased. The new satellite has a different SSID and username password. It ...
CrimpOn
Oct 29, 2022Guru - Experienced User
Before connecting the new satellite, do a Factory Reset on it. i.e. hold a tiny object such as the end of a paperclip or a SIM card ejector in that tiny hold next to the power switch labeled "Reset" until the power LED turns amber and begins to flash. When connected to the primary system, it should broadcast the primary WiFi name and use the primary WiFi password. (and other networks if you have them, such as Guest, IoT, Employee, etc.)
