paulwhita
Mar 05, 2024Aspirant
MR80 Connecting more than 60 devices
I am trying to connect 120 devices to this router. I have had times where it would handle the load just fine and other times where it will not handle more than 60 at a time. The router is wired to a ...
Mar 05, 2024Guru - Experienced User
120 devices is pushing it. Its a little different if there is a bunch of low bandwidth IoT devices but 120 cell phones, are going to use a lot more bandwidth/resources.
https://kb.netgear.com/24043/How-many-WiFi-client-devices-can-my-NETGEAR-router-support
It can help if you add a satellite (especially hardwired) since then it can take some of that burden but if you're just using the router, that 60ish is a bit more reasonable.
Usually when users are needing that many devices, its time to switch over to the business class equipment. Plus adding extra access points
- paulwhitaMar 05, 2024Aspirant
The cell phones are only sending and receiving data via a web browser. I do not think bandwidth is the issue.
