paulwhita
Mar 05, 2024Aspirant
MR80 Connecting more than 60 devices
I am trying to connect 120 devices to this router. I have had times where it would handle the load just fine and other times where it will not handle more than 60 at a time. The router is wired to a ...
Mar 05, 2024Guru - Experienced User
120 devices is pushing it. Its a little different if there is a bunch of low bandwidth IoT devices but 120 cell phones, are going to use a lot more bandwidth/resources.
https://kb.netgear.com/24043/How-many-WiFi-client-devices-can-my-NETGEAR-router-support
It can help if you add a satellite (especially hardwired) since then it can take some of that burden but if you're just using the router, that 60ish is a bit more reasonable.
Usually when users are needing that many devices, its time to switch over to the business class equipment. Plus adding extra access points
paulwhita
The cell phones are only sending and receiving data via a web browser. I do not think bandwidth is the issue.
