jwersan
Nov 21, 2024Tutor
MR80 crashes/resets several times a day
I've had the MR80 and its two MS80s for over a year, maybe two at least. I also have two MS60s hanging off of it, all are working as expected, I.E. connectivity. Since I initially set it up, I've h...
Nov 22, 2024Guru - Experienced User
How big is your home?
That seems like a lot of satellites.
what happens if you power a few of the satellites down?
I know they added compatibility with one of the firmware's for the MS60 and MR80 but later I'd seen a post that they'd removed those compatibilities. So try powering them off and seeing how it works. You might have to downgrade firmwares if you want to keep the compatibility.
- jwersanNov 22, 2024Tutor
plemans wrote:How big is your home?
I have a medium-sized house, but my computer is less than 10 feet from the MR80, which I am hardwired directly into.
The satellites never lose connectivity, it just seems that the MR80 crashes or resets for unknown reasons...The MR80 is in one corner of the house, where the cable enters, and the closest satellite is maybe 30 feet at most from the MR80. I get a good signal and throughput to all the satellites...
- plemansNov 22, 2024Guru - Experienced User
Medium sized means different things to different income levels. Your medium might be my large. And you can have to much coverage. What sq footage is it?
