jwersan
Nov 21, 2024Tutor
MR80 crashes/resets several times a day
I've had the MR80 and its two MS80s for over a year, maybe two at least. I also have two MS60s hanging off of it, all are working as expected, I.E. connectivity. Since I initially set it up, I've h...
jwersan
Nov 22, 2024Tutor
michaelkenward wrote:What modem/gateway/ optical network termination (ONT) connects you to the Internet?
Just another user with time on their hands.
I have comcast with their XB7 cable modem wired into the MR80.
Nov 22, 2024Guru - Experienced User
the XB7 is a modem/router combo device. Is it in passthrough mode or the MR80 in access point mode? Otherwise you're in a double nat
- jwersanNov 25, 2024Tutor
I can put it into bridge mode but I don't think this is the root cause of the crashes...
- plemansNov 25, 2024Guru - Experienced User
I would try that option.
You can also try shutting down a few satellites to see if something is causing a loop
- jwersanNov 26, 2024Tutor
I've done that and it ddin't seem to affect the problem...
Now to add insult to injury, the constant crashing has stopped.
Nothing has changed and I haven't implemented any changes either.I had at one time assumed it might be an overheating issue but that
wouldn't allow it to recover and work for several hours...
I hate intermittant issues like this...😡
