swagner4201
Sep 11, 2024Aspirant
MR80 Disable IPv6
I have a HDHOMERUN Flex4k and their support is telling me to disable IPv6 to try and troubleshoot an issue I'm having. I'm not seeing a way to do that on this router. Am I missing it somewhere?
Sep 11, 2024Guru - Experienced User
Log in via the browser. Its under the advanced tab and then advanced.
You can find the manual here:
NIGHTHAWK MR80 | WIFI 6 SYSTEM | NETGEAR SUPPORT
Its usually disabled by default.
What modem/gateway is the router connected to?
