rjpiselli
Jan 19, 2023Tutor
MR80 Ethernet Backhaul
How do I force wired backhaul? I have the MR80/MK83 router and 2 MS80 satellites. The satellites are hardwired, but only 1 of them is using wired backhaul (it is farthest away/most likely to be o...
- Jan 19, 2023
Check the cable.
Take the satellite and connect it to the router with a good quality cat 5e/6 cable that's only like 6 ft long. Give it 5 minutes (to switch over), then check the app/browser.
Jan 19, 2023Guru - Experienced User
How do you know the wired backhaul isn't working?
What does it show when you log in through the browser (don't trust the app)?
Have you tried a different cable between the 2 (for testing, use a short 6ft cable just to ensure its not the cable)
- rjpiselliJan 19, 2023Tutor
The app shows the wireless icon for 1 satellite, and the wired icon for the other. Also in the app, if I click on the satellites and click details one says 5Ghz and the other says Wired.
On the admin console through a web browser is shows connection type = 5Ghz for one, Wireless for the other.
- plemansJan 19, 2023Guru - Experienced User
Check the cable.
Good call. Must have been a bad ethernet cable.
Should have been the first thing I checked but didnt have issues (that i knew of) with my previous setup so assumed it was a config with the new setup.
THANKS!!
