rjpiselli's avatar
Jan 19, 2023
MR80 Ethernet Backhaul
How do I force wired backhaul?   I have the MR80/MK83 router and 2 MS80 satellites. The satellites are hardwired, but only 1 of them is using wired backhaul (it is farthest away/most likely to be o...
  • plemans's avatar
    Jan 19, 2023
    Check the cable.
    Take the satellite and connect it to the router with a good quality cat 5e/6 cable that's only like 6 ft long. Give it 5 minutes (to switch over), then check the app/browser.
