Jrmjenash
Dec 13, 2023Aspirant
MR80 keeps losses connection to satellites
I'm having an issue with my satellites keep losing connection to my router. I have 1, MR80, router with 5, MS80, satellites. The router is in the basement with one of the satellites in the kitchen ...
Jrmjenash
Jan 08, 2024Aspirant
With the holidays and vacation I haven't had a chance to move the router yet. I will do that in the next week, although I don't think that will take care of my problem b/c after we lost power only 1 of the satellites re synced with the router and that one is the furthest one away from it, while the closer ones won't.
Is there an option that I can setup on these units that will force them to automatically reconnect to the router when they become un-synced? I'm currently on vacation and we lost power to the house for a short time but when it came back on none of the satellites have reconnected to the router. Kind of inconvenient when the satellite that all my cameras are connected to never re-established connection to the internet. When one satellite is down how come devices don't connect to another satellite? Isn't that the whole purpose of a mesh system? Unless I don't have these setup correctly I'm beginning to dislike Netgear mesh systems. Any help on this would be greatly appreciated.
Jan 08, 2024Guru - Experienced User
Please give feedback for the questions presented so we can give you feedback.
- JrmjenashJan 08, 2024Aspirant
T-Mobile Arcadyan KVD21 - LAN cable is cat6
Ranch house, main floor approx 1200 sqft and basement approx 1200 sqft.
What channel configurations are currently set on the router?
I'm on vacation at the moment and only have access via the app so I'm not sure the channel, but I believe it is set to Auto.
Any Wifi Neighbors near by? If so, how many?I believe there are about 4 other Wifi SSID signals, but are very weak.
I did update all the firmware's as of Dec 15, 2023.
- FURRYe38Jan 08, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
For that size of home, the MR and just one MS should work well.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
