Goo2SeeYou
May 17, 2022Follower
MR80 Mesh Resets to DeFault
I have been struggling with my MR80 Mesh network for a year now. I set the SSID and new password and then about once a week it resets itself to the default (NETGEAR62) and I have to set up the SSID again.
Firmware says it is up to date. V1.1.6.14_3.1.101
Changed channels to see if that made a difference -= not
Can anyone shed some light before I throw the system out
1 Reply
Try doing this.
manually reinstall the firmware to the router and satellites. Then do your own factory reset and reinstall.
If something is corrupt in the firmware or settings, doing both should clear that out.
