basicfacekick
Aug 07, 2023Aspirant
MR80 MS80 backhaul dying, incredibly slow speeds on satellites
We have the MR80/MS80 Nighthawk Mesh system. Since purchasing we've seen issues where laptops or devices connected to a satellite will suddenly see plummeting speeds. Normally we get minimum 300+...
michaelkenward
Aug 08, 2023Guru - Experienced User
Usual basic boilerplate questions, what firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
basicfacekick
Aug 08, 2023Aspirant
Hi there. Firmware is V1.1.7.14_3.1.109 on the router and satellites. This wasn't a firmware available in the Check for Updates part of the configuration page, the Netgear tech had me go and pull this from the Netgear support site.
The Netgear is behind an Arris BGW210-700 from AT&T fiber. Both 2.4 and 5ghz wireless radios on the Arris are disabled. Yes this is also a router i.e. it has LAN ports on the back of it, its own wireless capability etc.
- FURRYe38Aug 08, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-modeTry option #2 first...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- michaelkenwardAug 08, 2023Guru - Experienced User
Turning off the wifi on the Arris does not disable the router section. So you have piled router on router.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.arris bgw210-700 bridge mode - Google Search
Sometimes it is easier to put the second router into AP mode. Netgear advises this, as does just about every site you will visit.
But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support- basicfacekickAug 08, 2023Aspirant
Thanks all.
I think I'll try putting the Nighthawk into AP mode first.
The Arris modem has a IP Passthrough but apparently not a true bridge mode. Maybe I'll be brave and try that first... not sure.
Honestly I'm not aware of any residential ISP that doesn't give you a router, so I'm surprised that Netgear wouldn't play well in this situation out of the box or at least shout very loudly about putting your ISP router into bridge/whatever mode. Most consumer-grade hand-offs from ISPs aren't dumb devices, they try to do ... well, everything, wifi, content filtering, etc. etc., but anyone buying a Mesh network clearly wants more coverage than their ISP provides.
IP Passthrough is same or and DMZ. Just passed everything thru to the IP address configured here. If the MR was in router mode, using the IP Pass thru will help with having a double NAT condition if you use the IP Pass thru feature. If you configured AP mode on the MR, then don't use the IP Pass thru feature.
