basicfacekick
Aug 07, 2023Aspirant
MR80 MS80 backhaul dying, incredibly slow speeds on satellites
We have the MR80/MS80 Nighthawk Mesh system. Since purchasing we've seen issues where laptops or devices connected to a satellite will suddenly see plummeting speeds. Normally we get minimum 300+...
basicfacekick
Aug 08, 2023Aspirant
Hi there. Firmware is V1.1.7.14_3.1.109 on the router and satellites. This wasn't a firmware available in the Check for Updates part of the configuration page, the Netgear tech had me go and pull this from the Netgear support site.
The Netgear is behind an Arris BGW210-700 from AT&T fiber. Both 2.4 and 5ghz wireless radios on the Arris are disabled. Yes this is also a router i.e. it has LAN ports on the back of it, its own wireless capability etc.
Aug 08, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
