Bryvsspy
Apr 16, 2024Tutor
MR80 no wifi connection
Hello, I purchased a MR80 + 2 satellites in July of 2021. Since then, I've had the unit replaced 2 times and my 3 unit stop working this past weekend. The units simply stopped allowing me to conn...
Apr 16, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between MR 📡 and MS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡 🛰️
Does this happen with the MS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
FYI, Case numbers are not handled here in the forums. Only troubleshooting and user to user help here.
Any official NG support needs, you'll need to contact NG support thru those case numbers.
