StrixKuriboh
Sep 30, 2023Aspirant
MR80: Satellites become unusable after time while main router is fine?
I am trying to solve an issue with the MR80 that's being used in a roughly 2200 square foot home. The main router is located next to the modem in the basement of the house. Satellite 1 is located in ...
- May 06, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
StrixKuriboh wrote:
I completely forgot about this but your suggestion did end up being the solution. Removing one satellite has made the entire system much more stable. The current setup is the main router in the basement and one satellite on the other far end of the houses first floor. Everything seems to work without a hitch and I have had it running this way for months now. Thank you.
StrixKuriboh
It is a hitron modem provided by Armstrong cable. The model name is Coda-45
michaelkenward
Oct 01, 2023Guru - Experienced User
Standard cable mode. Nothing of a router component to get in the way.
DOCSIS 3.1 Cable Modem | CODA-45 | Hitron
Just wanted to eliminate that from the troubleshooting.
