wow2007
Nov 19, 2022Aspirant
Mr80 wifi mesh slow speed
Hi, i recently bought a netgear nighthawk wifi mesh mk83 triband ax3600 3 pack. 1 router and 2 satellites. I have a tri level home with the router in the lower level and 1 satellite in the mid level a...
wow2007
Nov 22, 2022Aspirant
Hi,
Firmware version is v1.1.7.12.
My xfinity modem is an arris model # TG862G/CT. I am using a cat6 between xifinjty modem and nighthawk mr80.
My home is 1700 sq feet. router and satellite is 30 feet apart.
I changed the channel to 6 for 2.4 ghz and 48 for 5ghz since I saw your reply and my internet was okay for about a day. The next morning it slowed down again from 250mbps to 3 mbps. So i unplug then plugged in the router and satellite but this time change the channel to 1 for 2.4ghz and 40 for 5ghz. I did this yesterday morning and the internet was fine the whole day. Today when I woke up, internet was slow again.
Nov 22, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
- wow2007Nov 22, 2022AspirantI had the xfinity modem disable a long time ago. It is modem only. I’ve had it for 6-8 years now. I was using a linksys wifi which was working good but it was old already so I decided to replace it and bought the nighthawk mk83.
- FURRYe38Nov 22, 2022Guru - Experienced User
Wondering if there is still a problem between the MR and your Modem.
Only other item I would try is to put the modem back into router mode. Disable ALL wifi radios on the modem.
Use the modems DMZ for the MR. Reboot everything. I might power OFF the modem and MR for 1 minute then back ON.
Has a factory reset on the MR and MS been performed this last update?
- wow2007Nov 22, 2022AspirantI did try unplugging and rebooting only. Is factory reset the same as reboot? I’ll try the dmz
