wow2007
Nov 19, 2022Aspirant
Mr80 wifi mesh slow speed
Hi, i recently bought a netgear nighthawk wifi mesh mk83 triband ax3600 3 pack. 1 router and 2 satellites. I have a tri level home with the router in the lower level and 1 satellite in the mid level a...
wow2007
Nov 22, 2022Aspirant
I did try unplugging and rebooting only. Is factory reset the same as reboot? I’ll try the dmz
Nov 22, 2022Guru - Experienced User
No. Not the same as a reboot.
Try the DMZ first, last resort is the factory reset and setup from scratch using a wired PC and web browser.
- bulldog00Nov 26, 2022ApprenticeI am also having the same issue. Seemed to only arise after the latest firmware push 1.1.7.12.
Hardwired or from rhe router I get proper speed; but wireless is much less; even when sitting right next to the router.
